Notifications in Mosaic
In for example the ready widgets like "alarm sensor" you get notification on the page entering page if something is in alarm.
I am wondering if there is a possibility to set this for other widgets and specially in the widget creator.
Setting this option for icons inside the widget creator.
Is there some option for this?
Use Alarm element in WC, it has option to add alert text.
Found it, had completly overlooked it. Thanks.
Is there some chance to get these alarm text to pop up in the "Alerts manager" or do i need to add script to add them there.
Also the push notification for the alarms. Do you need to add the push script for every new alarm you want pushed to the phone.
The alerts in Mosaic are purely Java Scripts so they generated on the client device not on the LM itself. To use Alert manager you need to create separate alerts in script, the same for push notifications.
Hi, can you please send sample of the script alerting client ?
In mosaic? There is no script for that. Each widget which has 'alert' text in object will generate alert and this is build in the widget itself already. In Widget creator you can use alert element to create your own alerts.
