Visu SVG
Im wondering if it's possible to edit an svg image/code values with grp addresses. Not sure if this is even possible...
As a test I want to edit the width of a simple box with a grp address. If the value of the grp address increase it will get wider and vise versa.
Best regards,
Marcus H
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <!-- Created with Inkscape (http://www.inkscape.org/) --> <svg    xmlns:dc="http://purl.org/dc/elements/1.1/"    xmlns:cc="http://creativecommons.org/ns#"    xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"    xmlns:svg="http://www.w3.org/2000/svg"    xmlns="http://www.w3.org/2000/svg"    xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"    xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"    width="100mm"    height="50mm"    viewBox="0 0 100 50"    version="1.1"    id="svg874"    inkscape:version="0.92.3 (2405546, 2018-03-11)"    sodipodi:docname="Bar.svg">   <defs      id="defs868" />   <sodipodi:namedview      id="base"      pagecolor="#ffffff"      bordercolor="#666666"
See this thread: https://forum.logicmachine.net/showthread.php?tid=1831
You can apply scale transform instead of rotate. See this for more info: https://developer.mozilla.org/en-US/docs...the_origin
