Threads: 108
I cannot find the way to fix the layouts in the exact position of the page I want (example botton for menu, top for logo and time and date).
Could you help me please?
Threads: 35
Do you use the same resolution for layout and the page?
Threads: 35
Layout should have the same resolution as plan otherwise you will have the issue you describing. Why do you want different resolution?
Threads: 108
In order to simplify the way of built the visu.
I mean that instead of use a different software to build the page design I could use the layout.
This is just a curiosity.
Threads: 8
Normally you set the lay-out in the same resolution as the plan, on the lay-outs you usally set items that are default on multiple plans like date/time, menu, company logo etc.
On the plan you set the light buttons, status leds etc and attach the lay-out to this plan to complete it as a total.
