Change Background Image On Object Value
Hello All,
Is there a way to change the background image of an image element via object value?
Or can I have 4 sets of elements including images, buttons, value dispaly on the same page and change the visibility of them based on a virtual object 250byte value?
Value 1 = Make visible set 1 and hide all the other sets
Value 2 = Make visible set 2 and hide all the other sets
Value 3 = Make visible set 3 and hide all the other sets
Value 4 = Make visible set 4 and hide all the other sets
Thank you in advance
have you seen this? https://forum.logicmachine.net/showthrea...05#pid2205
Hello Daniel.
I have done this and works but if I refresh the page the background image is lost. Is there a solution to this?
$(function(){
    grp.listen('32/1/4', function(object, state) {
      var image = $('.hvac_image')[0]
      if (state == 'value') {
        if (object.value == 1) {image.innerHTML = '<img src="scada/resources/img/HVACFlowDiagram1.PNG?1569506491">';}
        else if (object.value == 2) {image.innerHTML = '<img src="scada/resources/img/HVACFlowDiagram2.PNG?1569506498">';}
        else if (object.value == 3) {image.innerHTML = '<img src="scada/resources/img/HVACFlowDiagram3.PNG?1569506503">';}
        else if (object.value == 4) {image.innerHTML = '<img src="scada/resources/img/HVACFlowDiagram4.PNG?1569506509">';}
Thanks for your help.
Currently your script is executed on state "value", this means that during init the script is not executed as state is "init" in that case, you could remove the "if (state == 'value') { ... }" condition to have it also executed on init so it is directly triggered after a refresh. Or you can add a extra condition like "if (state == 'init') { ... }"
