Siegenia AEROPAC
Next device to control: the Siegenia AEROPAC Smart
There is one product on the web that supports this device, iobroker:
https://github.com/Apollon77/ioBroker.siegenia
Is it easy to control them with a LM/HL?
I see they use a websocket in: https://github.com/Apollon77/ioBroker.si...iegenia.js
See this thread for websocket library: https://forum.logicmachine.net/showthrea...23#pid7823
mmm i only receive a 1006 error
* arg: 1   * nil * arg: 2   * nil * arg: 3   * bool: false * arg: 4   * number: 1006 * arg: 5   * string: wrong state
iIp  = '192.168.x.x' iUsr = 'admin' iPwd = 'xxxxxxxx' if not ws then   ws = require('user.websocket')   url = 'wss://'..iUsr..':'..iPwd..'@'..iIp..':443/WebSocket'   -- mode is either sync or copas, second parameter sets timeout in seconds   client = ws.client('sync', 10)   client:connect(url) end log(client:receive())
Anyone a suggestion how to find a detailed error?
30-10-2019: change the protocol from ws to wss gives no error 1006, but how to control the box?
i like to turn this device on/off and set my fanlevel.
Who can help me?
From JS code it looks like you don't have to pass user/password via URL but send a login request via WS.
Each request is encoded using JSON:
login = json.encode({   command = 'login',   user = user,   password = password,   long_life = false, })
For On/Off and fan control try this (change deviceactive value as needed):
req = json.encode({   command = 'setDeviceParams',   params = {     devicestate = { deviceactive = true },     fanlevel = 3, -- 0..7     fanpower = 50, -- 0..100     } })
Either fanlevel or fanpower value is needed, AEROPAC probably uses fanlevel.
There's missing id parameter in my example. Use this helper function to send requests:
function send(data)   reqid = (reqid or 0) + 1   data.id = reqid   data = json.encode(data)   return client:send(data) end send({   command = 'login',   user = iUsr,   password = iPwd,   long_life = false, }) send({   command = 'setDeviceParams',   params = {     devicestate = { deviceactive = false },     fanlevel = 0, -- 0..7   } }) send({   command = 'logout' })
If you want to keep the connection open then you should send keep-alive every 10 seconds or so:
send({   command = 'keepAlive',   param = {     extend_session = true   } })
(30.10.2019, 14:40)admin Wrote: There's missing id parameter in my example. Use this helper function to send requests:
Many thanks, it works great..  Big Grin
