1-wire pullup resistor
Do I need a pullup resistor for 1-wire temperature sensors ds18b20 connected to Re:actor?
Are you powering it from 5V or using parasitic power? From datasheet: VDD must be grounded for operation in parasite power mode.
(08.10.2019, 11:07)admin Wrote: Are you powering it from 5V or using parasitic power? From datasheet: VDD must be grounded for operation in parasite power mode.
 3 wires: +5v, GND, Data.
Pull-up is not needed but you can get more reliable readings by adding a capacitor (at least 0.1uF) between +5V and GND as close as possible to the sensor.
(08.10.2019, 12:05)admin Wrote: Pull-up is not needed but you can get more reliable readings by adding a capacitor (at least 0.1uF) between +5V and GND as close as possible to the sensor.
Thank you.
