Sony Bravia script
In another post i see a script to control a Sony television, so i try it with my HX850, but it doesn't work.
After some research i see its another way to control. Here my first test code
require('socket')
-- bravia IP
ip = 'x.x.x.x'
port = 80
-- full commandlist see: http://www.openremote.org/display/forums/Sony+TV+HTTP+control
cmd_HDMI1 = 'AAAAAgAAABoAAABaAw=='
cmd_CH6 = 'AAAAAQAAAAEAAAAFAw=='
cmd_MUTE = 'AAAAAQAAAAEAAAAUAw=='
ircmd = cmd_MUTE
soap = '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1"><IRCCCode>'..ircmd..'</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>'
-- http request
reqs = 'POST /IRCC HTTP/1.1\r\n' ..
      'CONNECTION: close\r\n' ..
      'HOST: ' .. ip .. ':' .. port .. '\r\n' ..
      'CONTENT-LENGTH: ' .. soap:len() .. '\r\n' ..
      'CONTENT-TYPE: text/xml; charset="utf-8"\r\n' ..
                '\r\n' .. soap
sock = socket.tcp()
sock:settimeout(3)
res, err = sock:connect(ip, port)
if res then
 res, err = sock:send(reqs)
 if res then
   log('send OK')
   log('send failed: ' .. tostring(err))
 log('connect failed: ' .. tostring(err))
sock:close()
Thanks for sharing, code in other post uses low-level API while you are using high-level HTTP. In theory both should work the same Smile
strange, i can't get the low-level code working on my KLD-40HX850.
I receive "connect failed: connection refused" when i connect on port 20060.
I can connect on port 80 but then the commands doesn't work.
(26.02.2016, 18:23)gjniewenhuijse Wrote: strange, i can't get the low-level code working on my KLD-40HX850.
Have you try this?
In order to enable this protocol, either one of the following settings needs to be enabled.
Normal Mode
Network > Home Network Setup > IP Control > Simple IP Control
Hotel/Pro Mode
Hotel/Pro Mode > IP Control > Simple IP Control
Have you try this?
Normal Mode
Hotel/Pro Mode
For my tv i enabled remote renderer in home network.
Hello everybody!
Its can work with KD65-X8500D ?
