Mosaic 3 Release?
Hello
What is the roadmap of mosaic 3?
Current 3.x development is still ongoing and not stable enough for customers in my opinion
- trends cannot be configured anymore with widget builder on chrome nor safari
- media widgets are finally back but do not render well for volume control
Any update ?
To be honest Mosaic is in constant development as we keep extending its functionality but we release stable versions once a while. The trend issue was missed. Which media widget do you mean exactly?
The trend issue is fixed
Hi Daniel,
Thanks for fixing the trends widget.
Other widget that is broken is the rendering of the media widget, the slider for the sound level is not rendering correctly
OK what is the name of this widget?
Music widget
Fixed
Thanks Daniel, indeed fixed Smile
Hi Daniel, I take the opportunity of this thread for a question. Have you a manual to use Mosaic? I would like to manage my own widget but I can know, for example, how to set json file. Could you help me please? Thanks.
Hi, use widget creator. There is no need to create json manually.
(11.02.2020, 08:32)Daniel. Wrote: Hi, use widget creator. There is no need to create json manually.
Yes, your right. But there are some elements on which I would like to change the color and it is not possibile. It is only light blue.
give me example please.
(11.02.2020, 09:10)Daniel. Wrote: give me example please.
Widget creator -> add element -> number with - (minus) and + (plus) which I would like to use for setpoint.
Like that?
(11.02.2020, 09:59)Daniel. Wrote: Like that?
Right, but in the setting of the element I cannot find the textcolor.
It is not there, You change that by going to Styles and Default widget styles.
