Creating a heating curve
Hello everybody,
I am totally new to this business and hope someone can help me.
I want to regulate a heat pump depending on the outside temperature.
Therefore I want to create a heating curve in the Block editor.
My Input is the outside temperature. If the outside temperature (X) is for example 5 degrees I want the particular Y-value for this as an output (Deputy signal).
In the FB editor I can find straight curve functions with 2 points at advanced math functions. Is there also a way to create a bent curve?
Hope somebody can help me  Huh
It will be easier to write a short script for this. What kind of curve do you want? Do you have a math formula for that?
