IP Router Feature
We want to set the Logic machine as an IP router, but do not get here. What settings do we have to make?
The controller must be defined as TP UART or IP Router. Do we have to turn off the IP feature?
You need to set the physical address to x.x.0, set the mode to TPUART and make sure that the checkbox  IP features is enabled. Optionally you can set the filters to manage the traffic. I would also advise to enable “acknowledge all group telegrams” to avoid possible repeats. Do not change the KNX multicast setting.
With settings above it should work fine.
