Query trends
I have a KNX installation where I want to have historical data from some parameters (temperatures, humidity, etc.). I want to use the logic machine as database.
Then I have to export this data to a software like Power BI. Here are the connections that this software can use: https://docs.microsoft.com/es-es/power-b...ta-sources
I'm opened to explore different ways but I would like that it could be the most simple way. For example that the Power BI can do queries to the Logic Machine database, but I don't know if it's possible.
Thanks in advance!
Check this
https://forum.logicmachine.net/showthrea...4#pid11144
(18.11.2019, 08:39)Daniel. Wrote: Check this
Thanks Daniel!
But I would prefer a solution like register the values in a SQL database. Is it possible?
