Weather stations
Which weather stations do you guys here use and which are easy to use within Our KNX / Logic machine environment?
Outdoor weather data:
It would be great to display outdoor weather data like outdoor temperature, Wind force, rain and humidity. I want to display these data when needed.
These data is also valuable when it comes to controlling outdoor sun protection, Logic for ventilation and other Logic needing input from weather data.
Indoor weather data:
Temperature, Air quality, Humidity etc. Great for controlling heat pump, AC and ventilation system.
Is there a great system of outdoor /indoor weather stations which integrates great With the Logic Machine (Wiser) and its Logics?  I see there are pure KNX weather stations, but also others like Netatmo and several others. It's a jungle out there and it would be great to here which you uses and how it Works.
Schneider Wiser (homeLynk), Power Tags, DALI, Multitouch Pro, Panasonic Heating pump, Flexit balansed ventilation, HUE integration, Lemus Speaker system. Tibber integration.
Ordered the Netatmo - excited to see if I can get it proper Integrated. Saw some scripts on the forum....
works perfect, indoor and outdoor devices
(06.12.2019, 12:10)gjniewenhuijse Wrote: works perfect, indoor and outdoor devices
Yes it Works like a charm.Netatmo up running.
Visually Integrated to my "touch" app and it is also nice to being able to use the data to control other devices if needed.
I needed to play around with it for a while before I cracked the code, but after that it went like a charm.
(02.12.2019, 22:57)stemic01 Wrote: Ordered the Netatmo - excited to see if I can get it proper Integrated. Saw some scripts on the forum....
Can you take the values of the netatmo as objetct in the LogicMachine?
I'm planning to add something to detect rain and outdoor values and make some routines with my Logic.
https://forum.logicmachine.net/showthrea...ht=Netatmo
