Threads: 6
26.11.2019, 12:26
(This post was last modified: 26.11.2019, 12:29 by zuuper.)
Whats the diff between Schneider Wiser for KNF and LogicMachine5?
I know W4K has a much higher price, but why and whats diffs?
My second question,
How can I find the version of LogicMachine5 Reactor GSM for KNX? I can only find with CAN FT. Every pictures of the product show with CAN FT :S
Best regards, Alexander
Threads: 21
It is pretty much the same. With LM you have some more apps. SE has also some specific apps for them self.
The Reactor GSM can be ordered in both versions, CAN FT or KNX, just specify which one you want.
LogicMachine5 Reactor GSM Power CANxLM5p-GMSC
LogicMachine5 Reactor GSM Power KNXLM5p-GMS
It is written in datasheet
Threads: 21
Well, the latest SE hardware is the same as LM. Software core is the same. This numbers were done based on some SE tests. Over the time there was 3 version of hardware. I don't know which version of HW they tested but most likely not the latest.
Threads: 40
LM has no defined limits in software
Threads: 6
28.11.2019, 10:48
(This post was last modified: 28.11.2019, 10:51 by Erwin van der Zwart.)
W4K has a limit in the 'unique' users you can create, this limitation is not in spaceLYnk just like the LM, the number of concurrent users is equal in all controllers and is also depending on the CPU model. HW3 has the most powerfull CPU and can (logical) handle more then a HW1 controller with older CPU model.
We tested the load for a longer term, when a visu is open the client's websocket is actively communicating with the controller and this basically determines the number of concurrent users.
If you have users with mobile phones the average total number is a lot higher then when using wall mounted panels as a phone only communicates with the controller during the usage where a wall mounted panel is always communicating.
