Threads: 44
I can get the Mjpeg image of my HIK ip camera displayed in visu, although the ip camera only supports one stream at a time over http, so if multiple clients try to view the image only one at a time can view it.
is there any way to view this in visu in a different format, onvif, h.264 rtsp or similar
i am trying to achieve all clients to view the image at the same time.
Many Thanks
Threads: 35
Unfortunately browsers do not support this. You could try to install some plugins but you will have to do it on every client device.
Threads: 87
May be you can try to save camera image to FTP and then it will be available to all customer... Such example exist here at forum. Of course it will not videostream, but customers will see every second screenshots..
Alex
It won't be solved unless camera manufacturers come up with a solution that will work natively in the browser. All current solutions require a separate hardware to act a proxy to convert camera RTSP stream to a format that browsers understand.
