Extra network card
Hi.
Is it possible to connect one extra network card to the LM? I have tried just connecting a small USB->Ethernet, but i can't see that it's shows up under "interfaces". Is there some other way to do this?
Kai-Roger
What is the use case for this?
(30.12.2019, 10:30)admin Wrote: What is the use case for this?
I'm wondering if it is possible to do a setup like in this picture:
Not directly, you need a router/switch that has vlan support if you want to isolate certain devices.
Ok. Thanks. I will look into that.
Sent fra min SM-G950F via Tapatalk
And if you don't need it isolated you can just connect both devices to the same network to make this work Smile
