Threads: 44
11.01.2020, 09:46
(This post was last modified: 11.01.2020, 09:46 by benanderson_475.)
i want to make a holiday function to run while customer is away, is it possible to capture a week worth of events, prior to the holiday period and replay these at the same time/s that they happened the previous week for as long as the customer is on holiday? in order to make this realistic.
Threads: 7
Not sure if LM support it but i think it does (we have it on W4K and SL) there should be an app in the controller appstore called “Presence Simulation” with this app you can create different recordings and activate the manual or by a object that you can link to a scheduler, add your holidays to the scheduler and all works automatically without the need if any script.
Note that you need to open the app as admin to select the objects that you can use within your recordings. After that any user can create the recordings with the released objects.
