logout redirect
Is there a way to change the url /logout redirects to ?
I want it to go to http://<ip>/scada-vis instead of http://<ip>/apps/
-John
Not possible directly, one possible solution is to overwrite default index.html file so when you visit http://IP/ you will be redirected to http://IP/scada-vis. Will this work for you?
(12.02.2020, 14:18)admin Wrote: Not possible directly, one possible solution is to overwrite default index.html file so when you visit http://IP/ you will be redirected to http://IP/scada-vis. Will this work for you?
How can i access the index.html file, while logged in with apps on ftp i cant find any files?
You cannot access it via FTP, but it can be written from a script:
io.writefile('/www/index.html', 'html data here')
(12.11.2020, 10:27)admin Wrote: You cannot access it via FTP, but it can be written from a script:
I tried and i manged to write to det html file, but it didnt solve my problem
This is my index.html file
<!DOCTYPE html><html><head><meta http-equiv="refresh" content="0;URL=/scada-vis/"></head><body></body></html>
Try clearing browser cache
