Threads: 161
(06.10.2018, 18:01)Erwin van der Zwart Wrote: (06.10.2018, 14:24)buuuudzik Wrote: Adding NodeJS +1
I was little curious what would be the Erwin opinion... Best Regards
Logic Machine is a powerful gateway and this would add very powerful and already existing new features and now also because better CPUs it could be possible.
Done is better than perfect
Threads: 5
(19.09.2018, 14:11)AEK Wrote: (18.09.2018, 13:39)Jørn Wrote: It would be great to get error log on non-existant group addresses used in scripts. you can use regular log()
log(grp.write('37/7/254', true))
and that was in log:
* arg: 1
* nil
* arg: 2
* string: not found
I really don't want to put that in every script with every object..
Best regards, Jørn.
Threads: 161
Maybe it would be a good improvement: multitype script.
Possibility to easily manage various type scripts which are the part of one system.
Threads: 20
About trends in 1 hour, he would be good to represent a day of 24 hours and not 23 as now.
One day that begins at 0 hour and finished at 24 hours.
jean-marc
Jean-Marc
Threads: 161
I think good option would be adding a place for name source addresses and then it would be possible to show them in Object logs
Threads: 161
And also in user.lib near "Save" button, "Reload scripts" button for reloading all scripts which uses this library. I know that some scripts could be running but there should be such possibility for manual reload.
Threads: 161
22.02.2019, 10:50
(This post was last modified: 22.02.2019, 10:51 by buuuudzik.)
I have another idea:
adding tags to grp.write, grp.update, grp.response:
Code: grp.write("1/1/1", true, "scheduler cmd")
Or even but not equal adding script id.
This could be visible in Object logs.
Threads: 6
23.02.2019, 18:45
(This post was last modified: 23.02.2019, 18:47 by Erwin van der Zwart.)
That is already possible:
grp.tag('tag name'):write(value)
grp.tag('tag name'):update(value)
grp.tag('tag name'):read()
Threads: 161
(23.02.2019, 18:45)Erwin van der Zwart Wrote: Hi,
Thanks Erwin for answer, this is only an idea. But I mean not update all addresses which are tagged but only a tool for better logging. E.g. ability to add some info to every command sended via script. It could be auto or manual e.g. grp.write("1/1/1", true, "sended from scheduler"). Of course it would be possible only on local LM. It could be visible in Object logs.
E.g.
Time | Address | Name | Value | Tag
14:05:10.300 | 1/1/1 | Lamp 1 on/off | off | schedule
14:05:10.500 | 1/1/1 | Lamp 1 on/off | on |constant-light
Threads: 40
You can override grp.sender field with any two characters. It will be displayed in object logs / source address column.
Threads: 161
This is something closer But I don't want override default data which could be useful. Perfect would be tags or script id + line.
I've checked also this sender property but it is visible only in DB, it isn't visible in Object logs.
But how can I change this property? I've tried change it in such way but without success (Source address = local):
Code: grp.sender = "s2"
grp.write("0/0/1", true)
Is this change is local or global?
Threads: 40
You are probably running an older FW version, this is how it looks in RC1:
Threads: 161
I've used demo LM on your site
Threads: 161
08.03.2019, 09:03
(This post was last modified: 08.03.2019, 09:46 by buuuudzik.)
You can think also about adding to Mosaic there functions:
- hiding icon when specific value of object,
- adding a function of only status showing for switching controls, not another control for statuses and another for switches. Especially this will be nice if control with text for ON/OFF would be only a status (it is very small and better for showing lot of states).
And also some rooms joiner.
Threads: 21
(08.03.2019, 09:03)buuuudzik Wrote: You can think also about adding to Mosaic there functions:
Please explain rooms joiner.
Threads: 161
08.03.2019, 09:55
(This post was last modified: 08.03.2019, 09:59 by buuuudzik.)
Function for join 2 rooms into 1 when. Join all objects of these 2 rooms into 1 room. Maybe split functions would be also helpful. Probably it could be possible now in JSON backup.
And also floor without rooms but which is the room, like Settings.
Threads: 71
I use multiple trends at visu, would be better if trend's names can be hidden. As example at my visu with 3 trends graphs mostly hidden by trend's names. May be we can switch on/off names?? Toggle key can be next after Graph and data... Or trend's names can be shown near Graph and Data keys, not on trend's field..
Threads: 40
@AlexLV, can you post a screenshot of you want to achieve? Probably this can be implemented with Custom CSS.
Threads: 20
Since we are on the trend, we should be able compare multiple trends with different dates, for example:
January 2018 temperature with January 2019 temperature.
Jean-Marc
Jean-Marc
Threads: 19
11.03.2019, 14:16
(This post was last modified: 11.03.2019, 14:17 by manos@dynamitec.)
Hello Everyone,
I would like to ask of a way to show error logs to the end client without giving admin access ot the configuration tab of the LM. I have Dali gateways on KNX side and I want to log all the group addresses that are indicating faults and show this on a list of erros so then end client can check it.
The default log function and object logs tab is nice but is there a way to access it without having admin access?
Kind regards,
