Logic Machine wishlist
(11.03.2019, 14:16)manos@dynamitec Wrote: Hello Everyone,
I would like to ask of a way to show error logs to the end client without giving admin access ot the configuration tab of the LM. I have Dali gateways on KNX side and I want to log all the group addresses that are indicating faults and show this on a list of erros so then end client can check it.
The default log function and object logs tab is nice but is there a way to access it without having admin access?
Kind regards,
Use alerts and alert manager app
Thank you Daniel for the quick reply. I will check the app.
@admin
In attachment is seen my problem - part of graphs is closed over by trends names:
How better correct this? Is possible to do if mouse is over just hide trend names for some seconds? May be add this to next firmware? If more trends - graph will not seen at all because of trend names
Alex
Trends are not optimized for smaller sizes. There are several things you can do via Custom CSS.
1. Hide legend completely:
.flotr-legend {
  display: none;
2. Make is partially transparent:
.flotr-legend {
  opacity: 0.5;
3: Remove border and background:
.flotr-legend {
  border: none;
  background: none;
Big thanks,
One of variants will be chosen, i think will solve my problem
