ESPA 4.4.4
Im wondering if the LM5 supports ESPA 4.4.4 protocol, since it's a RS232/485 protocol.
https://en.bxo.se/ESPA+4+4+4.html
with some quick searches on the forum i can't seem to find any old posts with this question.
Here's a short example script that can be used to poll slave nr 2. It does not send ack/nack and does not parse the message but can be used a starting point to check the communication. Change serial port name and parameters as needed.
EOT = string.char(4) ENQ = string.char(5) function poll(addr)   port:flush()   port:write(addr .. ENQ)   local buf = {}   while true do     local ch, err = port:read(1, 1)     if ch then       if ch == EOT then         break       else         buf[ #buf + 1 ] = ch       end     else       return nil, err     end   end   return table.concat(buf) end port = require('serial').open('/dev/RS232', { baudrate = 9600 }) res, err = poll(2) loghex(res, err)
