Threads: 67
So, reading about LM5 and Zwave compability, or the lack of it, I`m looking for a way to integrate som components in LM.
I have Aeotec 5gen stick and an rPi if needed.
Thanks in advance for sugestions.
Sent fra min SM-G950F via Tapatalk
Threads: 67
reason I'm asking is I have an IDlock 150, and it just won't show up in devicelist when adding.
Threads: 35
Check if your device is on this list
https://github.com/OpenZWave/open-zwave/...ter/config
if not then not supported.
Threads: 35
You should rather to ask them to update their profile on this site. When last time was updated this profile. It could be that we don't have latest.
Threads: 13
30.11.2020, 20:19
(This post was last modified: 30.11.2020, 20:41 by stemic01.)
(19.03.2020, 10:21)tomnord Wrote: https://github.com/OpenZWave/open-zwave/...fig/idlock
it's on the list.
I've sendt the xml to IDlock, and asked for them to check if there are any updates to their protocoll.
If they have an update, can I send it to you?
I just bought the ID-lock and got in installed now and is considering which route to go from here. The Z-wave or Zigbee route as you can get either module for the ID lock.
It would be very interesting to hear more about your story and if you were able to make this work proper. Did you get to integrate the ID-lock and were able to utillity it in a proper way? I want to follow your route with hardware and integration if it was a success. Any chance you can share your experience and how you made thins work?
Which Z-WAVE USB dongle is the newest recommended at the moment? Still this; "Currently ZWave Me USB stick is supported"?
Any model with an external antenna, or extended USB cable would give better reception conditions.
Schneider Wiser (homeLynk), Power Tags, DALI, Multitouch Pro, Panasonic Heating pump, Flexit balansed ventilation, HUE integration, Lemus Speaker system. Tibber integration.
Threads: 13
Following. Exciting. Will follow this and see if you find a way to make things work
