Best Camera for HL e SL
Hi Guys,
what is the best camera for HL and SL with Mjpeg video stream ?
I'm testing many manufacture but I don't found a very good solution (with professionals products).
Alberto
KNX Advanced Partner + Tutor
Hi Alberto,
did you find very poor the Mjpeg streaming? As many ip cam on market.
In the past I tried ONETECK and the quality of Mjpeg was very good like H264. Did you test it?
Axis and Vivotek. With Axis you could use 'Anonymous View' function so you don't need the basic authentication that doens't work anylonger in most browsers. The Vivotek camera has lots of possiblities and different stream profiles. Check https://www.ispyconnect.com/sources.aspx for all the streams from different brands. It's very helpfull.
thank you for you information.
I'm working with some mjpeg video and with jpg refresh (In the past I had some problems with the page refresh....now jpg snapshot works good).
I don't understand because the productors haven't a good document with the exact stream string....ispyconnect is often not correct
