Threads: 108
I would like to show with a written list all the sensors with value true.
Is it possible?
Claudio
Threads: 108
Thank you Admin.
Is it possible to use this option in Mosaic view?
Threads: 108
Thank you works great.
Only thing is that even if we use '\n') sensors list is in the same line. Any idea?
Unfortunately there's no unique ID for custom widgets. I'll ask the developers to add this feature.
Threads: 108
20.04.2020, 08:52
(This post was last modified: 20.04.2020, 08:56 by Domoticatorino.)
Thank you Admin. I appreciate it. Otherwise if we change CSS style, it causes the modify to all single widget in the project with the same format.
In any case, setting the text you suggest in the "CUSTOM CSS" field of Styles Mosaic modify simply the text of the main page. And not the widget of the another page. Are you aware about that?
Can you provide backup if your Mosaic project?
