best way to power off a LM ?
Hi all,
what is the best way to properly stop an LM before turning off its power supply?
It sometimes happens that when I cut the 24V, the LM offers me scripts that do not contain the latest modifications: I find myself in earlier versions without understanding why !
Very strange...
Take care of yourself.
Best way is via system -> system -> shutdown.
The controller has fixed save interval to store data permanently to the sd card, so changes between power cut and last save interval can result to lost changes.
If you change scripts the you might want to press the button “sync project data“ in the right bottom corner to force a SD card save..
Hi Erwin,
very clear ! Thank you.
Best regards from France.
Hi all,
is really the Lua command os.execute(powerOff) equivalent to a shutdown of the LM ?
Best regards.
os.execute('poweroff')
Ok, thank's Admin.
