Is possible to show script/process with ID which takes more CPU Load than treshhold
Last time I begin to monitor CPU load and temperature, and found out that sometimes some processes/sript(s) takes very many PLC time.
Is possible somehow monitor such processes/scripts, write them to log? Or if I set CPU load treshhold 70% - than receive in log detailed information?
Alex
You can monitor which process is consuming CPU manually by installing System load app from the store. Creating a monitoring script is possible but it's a complex task.
