Multiple Visualizations on the same LM
I have an installation with 6 Android tablets. Every tablet works as a room controller so I need to have a different visualization in each one. Is it posible to have 6 different visualizations on the same LM?
I have seen the Mosaic option but seems that only have 5 instances.
Thanks!
In custom visu you can create as many users you want and separate them by permissions.
(01.05.2020, 09:50)Daniel. Wrote: In custom visu you can create as many users you want and separate them by permissions.
I understand that I can create 6 different users and link a diferent plan for each one.
Which is the link I have to open to see the custom visu in the navigator?
IP/scada-vis you can also add direct link with page ID if you want IP/scada-vis#1
