LM IoT Edge
Hi all!
we are willing finally to launch our LM IoT Edge controller (maybe several versions?) which might bring much broader markets and solutions possible (out of regular home automation). We would appreciate your thoughts and ideas about perfect device for your solution.
Here is what we have on today. And what is possible:
  • 1 x LAN with Passive PoE
  • 1 x CAN FT (we might add KNX TP1 if there is a need?)
  • LoRa 433 built-in for deploying local wireless network for gathering sensor data etc.
  • 1 x RS485
  • 1 x 24V output
  • LTE module with SIM holder
  • Two options of SIM - either we supply prepaid data-plan for 10 years / 500 MB (Europe, Russia, USA, China) or you use your own, local SIM
  • Possible interfaces/extensions: Zigbee, Enocean, LoraWan 868, BLE,.. ?
  • USB
  • IP67 waterproof outdoor enclosure with glander
  • Can be supplied either with regular LogicMachine firmware or Debian based firmware (with ported CANx, Mosaic,.. apps)  for custom development
Thanks in advance!
[Image: lm-iot-edge-side.jpg]
[Image: lm-iot-edge-front.jpg]
Debian based firmware, open platform, built-in Zigbee, LAN, KNX (and CAN FT, but idk), RS485 and all in one is most fairy device could ever be. Of course there must be robust and user-friendly software which looks like Mi Home or Smartthings, not the current Mosaic is. Zigbee should support all devices possible updating device profiles from your server.
Still I does not understand why LoRa is your choice and why it is needed, can't see any "broad market user" use cases.
BLE should go in pair with NFC to quick connect to smartphone. Otherwise BLE is redundant.
LTE module should work out of box without any settings, otherwise it is redundant.
IMHO
Good luck
Hi Edgars,
I think that can be your best seller, depending solution/cost.
More and more clients ask for solutions to monitor consumption, technical alarmes, temperatures, etc
I know that some brands are developing sensors with sim prepaid data-plan for 10 years that read values in the installation and write to cloud (their own cloud).
This LM IoT Edge can be a good solution because we can read other sensors and can be configured to write to different platforms.
My opinion is to have different LM IoT Edge, with different communication interfaces and different costs, but there should have one low cost with:
[*]1 x LAN with Passive PoE
[*]1 x CAN FT (if don't increase price)
[*]LoRa 433 built-in
[*]LTE module with SIM holder
[*]Two options of SIM - either we supply prepaid data-plan for 10 years / 500 MB (Europe, Russia, USA, China)
[*]Zigbee
All the IP interfaces that already have in LM (Modbus, Bacnet, KNX, etc)
Hi you have new product thats fine, but I really do not understand why you work on new product when:
New iOS application is not released
Touch visualisation is not completely done (need improvement like multiselect, copy etc.)
Mosaic 3.0 is horrible.
Last official firmware is 2017...
Legacy Siri support...
a lot of significant improvements should be done but there is no visible progress for years Undecided
(06.05.2020, 13:35)Bitver Wrote: Still I does not understand why LoRa is your choice and why it is needed, can't see any "broad market user" use cases.
Thanks for your comments. Regarding your doubts on LoRa:
  • compared to all other technologies like Zigbee, Enocean, BLE - its is long-range. It allows us to form a long-range local wireless network to assemble sensor data (e.g. industrial site). If we compare to long-range technologies e.g. LoRaWAN doesn’t have any acknowledgment, mostly it is one-direction. We have implemented ACKs, repeats, ping-pong mode which monitors network state
  • we use 433 MHz (4x longer distance than 868 MHz, 433 MHz is less used, much less mobile network influence, much better wall penetration, less energy needed to transfer same amount of data as in 868 MHz)
  • multi-frequency with 8 non-overlapping channels
  • changeable band-width,  spread spectrum. You can configure either high-bandwidth/low-range low-bandwidth/high-range
  • strong security based on ChaCha20
As for new FW we're committed to release a stable version this summer with some new features included. RC versions can be used as well as they do not have any major bugs.
