Threads: 94
in order to reduce KNX traffic bus I have disable the flag "write to bus" in modbus oject map.
Unfortunately LM is going on to write on bus. What do you suggest?
Threads: 28
You can use Virtual objects but are you sure it is writing? Which fw do you use?
You can also add Value send delta: to limit traffic.
Threads: 28
What is latest one? My latest is definitely not the same what yours
RC1?
Threads: 94
You're right.
What I have downloaded from your post dated october 2019 for LM5 lite.
It is called lm5m3-20191015
