Threads: 87
To get the alerts into the "Alert manager" i guess they have to come from scripts first.
Does anybody have an example for me to get started, or a tip to get into using it?
Threads: 8
Just use the script command alert('This is my alert') and the alert manager picks it up automatically.
You can also use dynamic alerts like alert('The value of object ' .. grp.find(event.dst).name .. ' is ' .. event.getvalue() .. " degrees")
Threads: 87
Sorry, Erwin. Still as far getting this to work.
Would not know where to put this or where to make this work.
Would it be possible to ask for an example or a little more push in the right direction`?
How about an example about what you wish to achieve with a little bit more detail?
Threads: 30
The Erwin's script is for boolean for alarm with value 1. For temp above you can do similar
if event.getvalue() > 21 then
alert('Temp is above 21 in ' .. grp.find(event.dst).name)
