Customize spinner
Is there any way to customize spinners differently?
I need different colors and scaling in different pages
Also, in some pages I need vertical spinner and in some horizontal
Try this as a start
https://forum.logicmachine.net/showthrea...4#pid15624
(08.07.2020, 13:31)Daniel. Wrote: Try this as a start
I have done this and much more than this I have changed background color,buttons, boarders etc..
But! How can I have it vertically /not Horizontally and most important, how can I apply different changes to different instances of the spinner? As have already mentioned, I need a red horizontal spinner with green buttons in one location and on another location a vertical yellow spinner with blue buttons and red text
Do you use show control mode or pop-up element?
(08.07.2020, 14:59)admin Wrote: Do you use show control mode or pop-up element?
No I Don't
Use this CSS for vertical spinner for both show control and pop-up element (icon display). You need to set additional classes to s-vertical, icon display will only work correctly with 2020 RC2 firmware.
1234567891011121314151617181920212223242526
.pcontrol-s-vertical .popover-content, .usermode .s-vertical .popover-content {   display: flex;   flex-direction: column-reverse; } .pcontrol-s-vertical .spinner-up, .usermode .s-vertical .spinner-up {   border-radius: 4px 4px 0 0 !important; } .pcontrol-s-vertical .spinner-down, .usermode .s-vertical .spinner-down {   border-radius: 0 0 4px 4px !important; } .pcontrol-s-vertical .spinner-up, .usermode .s-vertical .spinner-up, .pcontrol-s-vertical .spinner-down, .usermode .s-vertical .spinner-down {   width: 54px !important;   margin: 0 !important; } .pcontrol-s-vertical .spinner-value, .usermode .s-vertical .spinner-value {   width: 52px;   border-top-width: 0;   border-bottom-width: 0; }
You can add multiple classes to an element if you want to change colors or other properties. For pop-up element display classes are prefixed with pcontrol- so s-vertical becomes pcontrol-s-vertical:
