Threads: 45
Does your shutter actuator support 4-bit objects? If so you can just use 4-bit control which has +/- buttons for control via press and hold.
Threads: 29
There is no such thing what you are looking for. Some users created a scripts with direct database write where they shifted groups of a template page. This will work only if you have certain pattern of object creation.
Here is an example
https://forum.logicmachine.net/showthrea...50#pid7450
Not sure what for but I wrote some script to shift visu objects based on selected shift. It may be useful to you.
planID = 8 --plan number shown after # in quisk visu preview http://URL/scada-vis/#6
visObjectType = 1 --all binary objects are type 0 and all numeric objects are type 1
--All Manin objects will be shifted by selected addres.
controlObjectMain = 0
controlObjectSub = 0
controlObjectAddress = 0
--Select shift for status object. If status object is not used in object visu it will be ignored.
statusObjectMain = 0
statusObjectSub = 0
statusObjectAddress = 0
------------------------------------------ End Parameters ------------------------------------------
------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE -------------------------------
dbobjects = db:getall('SELECT id, object, statusobject FROM visobjects WHERE floor = ' .. planID .. ' AND type = ' .. visObjectType .. '')
--log(dbobjects)
for _, tableData in ipairs(dbobjects) do
oldControlAddress = tableData.object
oldStatusAddress = tableData.statusobject
currentRow = tableData.id
newControlAddress = oldControlAddress + ((controlObjectMain * 2048) + (controlObjectSub * 256) + controlObjectAddress)
newStatusAddress = oldStatusAddress + ((statusObjectMain * 2048) + (statusObjectSub * 256) + statusObjectAddress)
log('oldControlAddress= '..tostring(oldControlAddress)..', currentRow= '..tostring(currentRow)..', newControlAddress= ' ..tostring(newControlAddress)..', newStatusAddress= ' ..tostring(newStatusAddress) )
db:update('visobjects', { object = newControlAddress }, { id = currentRow })
if (oldControlAddress == oldStatusAddress) then --if no status object selected main object must be used
db:update('visobjects', { statusobject = newControlAddress }, { id = currentRow })
db:update('visobjects', { statusobject = newStatusAddress }, { id = currentRow })
log('update finished')
script.disable(_SCRIPTNAME)
Always make a backup before using any of this scripts.
