I've added Door Status widget (tested on both mosaic2 and 3) and linked it with Open/Close type object. I'm not getting display logic here – why when object value is Open, widget is displayed as closed door, and vice versa? Should I create a shadow object and store inverted value via script or what's the best approach here? Can widget be fixed, is it by design, or at least "invert" option added as with some other widgets?
Thanks!
Thanks!
