29.07.2020, 08:52
		Is there any way for the DALI gateway to monitor the DALI bus and for example report a power failure or other communication problems?
					Monitoring the DALI bus
		29.07.2020, 08:52
		Is there any way for the DALI gateway to monitor the DALI bus and for example report a power failure or other communication problems? Thanks
		29.07.2020, 09:07
		canX dali has option to monitor DALI power supply short circuit status
------------------------------ Ctrl+F5
		29.07.2020, 11:21
		You can set up a script to periodically query ballast status. Then check the return value to see whether there was a valid reply or an error.
					« Next Oldest | Next Newest »
