27.08.2020, 08:20
LogicMachine5 Power KNX CANx DALI brings redundancy and maintenance possibilities of your installation to another level.
LM5 Power is an embedded platform with integrated Ethernet, USB, KNX/EIB, Serial interfaces. LM allows to use it as cross-standard gateway, logic engine, visualization platform, IP Router. Scripting templates provides user-friendly, flexible configuration interface and integration with cloud/web services, 3rd party devices. Via applying custom scripts LM can simultaneously act as thermostat, security panel, lighting controller, etc. LogicMachine application store and external app development possibility allows to extend device functionality and adjust to a specific market segment.
In comparison with DALI built in other LM5 devices (like DW1, DR, RD), you can use it as DALI Multi-master. The commissioning software for LM currently supports DALI1 only but we have plans to add DALI2 later. We support Date Type 8 (color temperatures) for DALI lighting + you can send and receive 1/2/3 byte telegrams.
Hightlights:
I/O specification:
![[Image: LM5p2_KCD.png]](https://openrb.com/wp-content/uploads/2020/08/LM5p2_KCD.png)
LogicMachine5 comparison table can be found here.
Hightlights:
- Power-over-Ethernet powering
- Application development and application store
- Cloud ready device with Microsoft Azure, Amazon Web Services and other services supported
- Gateway and uniform way of control of KNX TP1, CAN FT, DALI, ModBus RTU/TCP, BACnet IP, DMX 512 and more
- Unlimited scenario and logic engine
- Unlimited visualization platform for PC and for touch devices
- Size: 4 DIN units
- Remote KNX bus control and KNX device reprogramming
- Object logging with trends support and data exporting to external servers
- iOS Siri and Google Voice control supported via native apps
- CANx configurator is freely available from LM app store
- CANx technology description can be found here
I/O specification:
- 1 x RS485
- 1 x RS485/RS-232
- 1 x 10/100 Ethernet with passive PoE support
- 1 x KNX TP1 (TP-UART2 physical layer IC)
- 1 x CAN FT
- 1 x DALI master
- 1 x USB2.0
