How add aditional info to push notifications
time ago I added push notifications to customer. He receives messages. But sometimes messages coming with delays, is possible to add time and date in to message and also group values? Trying to insert in message time and something else - anyway receiving just text message without additionally added info..
May be somebody can explain how to do my task..
Alex
You can build the string by combining many variables. As a result it still must be a string. Same way like you would make an alert.
Thank you Daniel,
I will integrate my data in my text message Smile
Alex
(09.09.2020, 07:08)Daniel. Wrote: You can build the string by combining many variables. As a result it still must be a string. Same way like you would make an alert.
Can you give as an example?
objectdata = grp.find('1/1/1')
msg = 'The value of ' .. objectdata.name .. ' is ' .. tostring(objectdata.value)
(13.09.2020, 18:24)Erwin van der Zwart Wrote: objectdata = grp.find('1/1/1')
msg = 'The value of ' .. objectdata.name .. ' is ' .. objectdata.value
Thanks Erwin!
