Threads: 148
Hello
A question about LogiMachine Reactor, can I send SMS via GSM, can the GSM also be used for a remote connection to the LM?
Thank you
Reactor GSM has a built-in modem which can be used both for SMS and Internet access. If you want to access LM directly then you will need a real IP address from your provider but this not recommended. Alternatively you can use VPN which is more secure.
VPN can be configured from the UI. But you need a VPN server for it to work.
Threads: 148
Exist a free VPN server to use , or need to setting my VPN OperVPN Server , my firewall not support OpenVPN.
This means that LM cannot reach the remote network. Check that you have a valid gateway in LM and that you can ping VPN server from LM (System config > Status > Network utilities > Ping).
Your config is not fully valid:
1. Replace auth-user-pass in your config with dev tun0
2. Don't forget to add two pull-filter lines I've mentioned before <ca> line
You need to enable client-to-client option in VPN server configuration.
