customize a circular slider
Hello, I want to customize a circular slider. I need the plus / minus buttons to look as big as possible. Then I have seen that it is possible to customize the color of the temperature bar but I was not able to achieve it. I want it to be Blue in Cold mode and Red in Heat mode.
For color change see this post: https://forum.logicmachine.net/showthread.php?tid=2120
If using default blue color then hue-rotate(160deg) filter will change it to red.
To make up/down icons bigger use this custom CSS:
.circularslider-min, .circularslider-max {
  font-size: 34px;
Hello, from the mobile access the thermostat is displayed wrong. Do you know why this happens?
Which hardware and browser version is that?
(02.10.2020, 15:34)admin Wrote: Which hardware and browser version is that?
From Safari browser in IOS updated to the latest version
Can you send backup via PM?
