Restoring a projet failed
Hi all,
I have a big problem with a HomeLynk (Schneider) in v2.3.0.
When I restore a project (.tar) the process goes without any problem, but then the HomeLynk remains in its initial state (new objects not created, new scripts not present ...).
What is going on ?
Embedded Systems SIA 2018
Schneider Electric 2018
FlashSYS v2
CPU ARM926EJ-S rev 5 (v5l)
Linux 4.4.145
Probably SD-card is in read-only state
Hi Admin,
and how to remove this SD-card status ?
I don't found a system menu to manage this, ans I never modify the read-only state...
You need to replace the micro-SD card. Follow this guide: https://openrb.com/reflash-logicmachine3...-software/
