Threads: 104
Dear all,
I have a LM with this CUP info "CPU/IO: 1.00 1.00 1.00".
How can I consider this values? Are good? Not good? How can I improve them if it needs?
Memory is 20%.
Anything above 0.7 is high load. Install system load app and check which process is consuming CPU.
Threads: 8
Yes you can use it in multiple scripts without changed, that’s why i use _SCRIPTNAME as storage name so each script has a unique name by default.
Threads: 86
Erwin, I have some old installations (based on old for now LM3). There also sleep commands many used. Is possible some how check how many parallel processes or scripts started on LM? Or I simply need to add additional script lines to every resident script to control loop processes? How to analyze such things?
Alex
Threads: 30
Each resident script has only one PID, only event can run many times in parallel
