reactor SMS modem reset
I try to send SMS with integate modem in reactor , in cofiguration I see ip address from Mobile network, but  in alarm page I have reset modem message , why?
what is the usb port for the internal modem of the reactor?
I have try 0 1 and 2
For built-in modem you need to disable the reset part. I've attached the latest script version (it has reset disabled by default). Port number depends on the modem that's installed in your LM. It can be either ttyUSB2 or ttyACM3
.lua   resident.lua (Size: 3.64 KB / Downloads: 3)
.lua   user.sms.lua (Size: 9.15 KB / Downloads: 3)
(12.10.2020, 13:41)admin Wrote: For built-in modem you need to disable the reset part. I've attached the latest script version (it has reset disabled by default). Port number depends on the modem that's installed in your LM. It can be either ttyUSB2 or ttyACM3
in the init script leave the code
os.execute('usbreset /dev/bus/usb/001/001')
or delete it?
Init is not needed for internal modem
(12.10.2020, 14:30)admin Wrote: Init is not needed for internal modem
Ok tank's
i test and now works all , but i have seen use the GMT time not the local time is correct , is possible change to use the local time ?
Do you mean LM time? You can set timezone in Utilities - Date & time
