[OLD] LogicMachine firmware 2016.04.16
#21
It seems there is a strange behaviour in the new FW or I am doing something wrong...
I have enabled the option "Save object values in storage:" just for testing and whenever LM writes something to BUS the device reboots.
Can someone confirm if this is a bug or misconfiguration on my side?
Thank you
#22
This issue has already been fixed, but can be present in your firmware. For now just keep it disabled.
#23
(24.06.2016, 08:14)admin Wrote: This issue has already been fixed, but can be present in your firmware. For now just keep it disabled.
Thank you flash gordon  Cool
#24
(05.05.2016, 07:00)edgars Wrote: Please see here pre-release of firmware.
Make sure you have a backup file of your device prior to upgrading.
Upgrade might take some time if you have many trend logs, during upgrade red/green LEDs will toggle.
Changelog attached.
LM2 IMX: https://dl.openrb.com/lm-16.04/lm2i.img
LM3 V1 (4 x RS-485): https://dl.openrb.com/lm-16.04/lm3v1.img
LM3 V2 (3 x RS-485 and 1 x RS-232): https://dl.openrb.com/lm-16.04/lm3v2.img
LM4: https://dl.openrb.com/lm-16.04/lm4.img
LM5: https://dl.openrb.com/lm-16.04/lm5.img
LM Ambient: https://dl.openrb.com/lm-16.04/lmwall.img
LM Reactor: https://dl.openrb.com/lm-16.04/reactor.img
LM Reactor V2: https://dl.openrb.com/lm-16.04/reactorv2.img
LM Reactor V3: https://dl.openrb.com/lm-16.04/reactorv3.img
LM Reactor Lite: https://dl.openrb.com/lm-16.04/rctl.img
How can i check my version on firmware to LM?
#25
AdriSaliai, please send me your device serial number in private message.
#26
Looks like removealltags is not working in the latest beta
local all=grp.all()
local gr
for k,i in pairs(all) do
     if(i.name ~= nil) then
       gr= i.address
       grp.removealltags(gr)
Also,  changes to tags on objects via script do not appear in the objects tag without having to refresh the browser.
Thanks,
Roger
#27
Thanks for bug report, Roger, will fix this before the release. Manual refresh is needed because auto-refresh only applies to value changes.
