Threads: 78
Hi guys,
Day problem..... I need a push button that must send a telegram only after if the user inserts the correct password. No status request. Any solution?
Best regards Cristian
Threads: 31
Use PIN protection. Every object has this option.
Threads: 31
For Mosaic there is dedicated widget for this. It is called Security.
Threads: 31
In that case I don't see anything out of the box. A solution for you could be a custom widget where a button will be linked to a virtual object and below another object as a password field. User will have to write correct password for the object to send value. A script will check if the password is correct or not. On successful send you should clear the password.
