Nano Temp Inveo - Temperature Sensor
Preface:
Manual:
http://download.inveo.com.pl/manual/nano...ual_en.pdf
Module:
https://www.tme.eu/at/en/details/nano-te...nano-temp/
Note: I try out several third-party sensors, but only the original Inveo sensors are working.
Sensors:
https://www.tme.eu/at/en/details/sensor-...nveo/ds-1/
https://www.tme.eu/at/en/details/sensor-...nveo/ds-5/
https://www.tme.eu/at/en/details/sensor-...veo/ds-10/
Question:
By the following .jons i get the output of 231°C (since it`s x 10 in accordance to the Manual)
  "manufacturer": "Hugo",
  "description": "Nano_Temp_Inveo_V1",
  "mapping": [
    { "name": "Temperatur", "bus_datatype": "int16", "datatype": "int16", "type": "register", "address": 4003, "units": "°C" }
But if i do this, i get the output of 23°C
  "description": "Nano_Temp_Inveo_V2",
  "mapping": [
    { "name": "Temperatur", "bus_datatype": "int16", "datatype": "int16", "type": "register", "address": 4003, "value_multiplier": 0.1, "units": "°C" }
How i get the output 23,1°C?
You have the wrong bus datatype, you need to use 2 byte float..
Thanks, it's 23.1 ° C now.
"mapping": [
{ "name": "Temperatur", "bus_datatype": "float16", "datatype": "int16", "type": "register", "address": 4003, "value_multiplier": 0.1, "units": "°C" }
