LM5 REACTOR
Hello
I have a problem, in the LM5 Reactor, I should leave the modem enabled for sending sms, but I should also be able to access the object remotely (external network), which tested does not work because the modem activates different routes, how can I solve the problem ?
I need both functions.
you could use our cloud, but as I understood you are using a regular visu, not Mosaic. Then the option is either OpenVPN (ready solution) or ZeroTier (we plan to release fw this week for Reactor)
