Threads: 7
I have a Wiser for KNX from Schneider Electric. How can I reach my Wiser using https and whithout having a security message when I try to connect to the webserver ?
Thanks,
Threads: 31
You will need SSL certificate, very painful process but can be done.
The built-in certificate is already self-signed. You can replace it in System config with your own certificate. If you don't want a warning message when using your self-signed certificate then you need to add your own root certificate to all devices that will be using your Wiser.
Threads: 31
Threads: 31
On Wiser yes, on LM we have simple app for it.
Threads: 20
Oké,
another reason to get a LM.
