Issue with IOS and Https connection
Hi every one,
I've an issue when I use an Iphone with an https connection.
I can see all the values and the update of each value on the vizualisation, but i can't modify the values.
For example when I want to set a byte value, I can see the slider, but the modified value is not upgrade to the logiccontroller.
I've observed this problem on Wiser4KNX, Spacelynk and LM5.
Is it an know issue ? Have you an idea to fix that ?
Thanks a lot
Adrien
Yes for years, apple is blocking websocket, nothing we can do.
(24.11.2020, 20:32)Daniel. Wrote: Yes for years, apple is blocking websocket, nothing we can do.
Okay, it's clear! Thanks for you answer
Thanks for your information: it's a problem of websocket, I found an experimental webkit on IOS, "NSURLSession WebSocket" and WebGPU, I try it on two Wiser4KNX and my Spacelynk , it fix the issue.
In my LM5, it work util i refresh safari.
Do you know this function ? maybe a know risk to use it ?
My apologise if someone already tried it before !
