change backgroud color
Is possible chaneg color backgroud of object in image
Tank's
For static background color just add an additional class, for example bg-red
Add to Custom CSS:
.bg-red { background-color: red !important; }
(27.11.2020, 08:47)admin Wrote: For static background color just add an additional class, for example bg-red
Add to Custom CSS:
ok
I add this code in Custom CSS:
for call the backgroud color in object  ?
nedd to add class bg-red , correct ?
tank's
as admin wrote add additional class to the object you want to apply this rule.
(27.11.2020, 10:50)Daniel. Wrote: as admin wrote add additional class to the object you want to apply this rule.
I try to black color and not work red yes Why ?
you will see the change only in final visu not in editor.
(27.11.2020, 10:59)Daniel. Wrote: you will see the change only in final visu not in editor.
Yes tank's a lot
Yes tank's a lot
As for the background in visu all OK, with the css I changed the value, but now even in the mobile view the background has become black, making me not read the writing well, it is possible to separate the 2 things and leave the background white ( default) in the mobile view keeping the black for VISU?
thanks a lot
Add .usermode to CSS rules:
.usermode .bg-red { background-color: red !important; }
