Heatmiser integration via API
Have a hotel complex with thermostats from Heatmiser with their Neohub in every hotel room. But i need to have signals from the thermostats over to the BMS system of the hotel.
This is Desigo CC and therefore i was thinking of using LM5 converting the signals from the Heatmiser converting it to bacnet.
With the API is this a realistic plan or would this be to difficult to do ?
.pdf   Neohub Api For systems developers.pdf (Size: 1.21 MB / Downloads: 30)
It's doable. The protocol is rather simple - JSON data exchange via TCP on port 4242. Do you want two-way control or just to retrieve status data?
The thought was 2-way control. Read and wright setpoints and hvac.
The device should support multiple connections so the easiest way is to have a single resident script (always connected) for periodical status retrieval and several event scripts that write values to the hub (one-time connection: connect-write-disconnect).
