Threads: 130
Hello
I am noticing that in touch I can vary the value of the set also of decimals as set in the parameters but in view this is not possible what I am doing wrong.
Value 2 Byte Floating, also tried to set Dt as temperature nothing to do.
Threads: 28
The object parameters got nothing to do with Touch(SE Touch) Only custom visu is using them. If Touch has option you should set it there.
Threads: 28
Show me example as I no longer sure what you mean.
Threads: 28
Do you use LM or SE version? This is important as they use same name for different thing.
Threads: 28
If this is on SE then where do you want to display this value? Drop a screenshot.
Threads: 28
Open it in final visu and use the arrows.
