Renewing SSL certificate
How can I replacing current ssl certificate with a new one e.g. from LM ftp?
Let's encrypt suggest to renewing at least one time per three months, so I want add some autoreplacing based on ftp on LM or downloaded from certificate server?
And how can I check certificate expiration date in Lua?
I found some instruction but I don't know how to use it with LM:
https://github.com/auto-ssl/lua-resty-au...enewal.lua
Done is better than perfect
The script that you've provided won't work on LM. At this point it's not possible to fully automate this process without an external server. We have plans to add a service that uses LetsEncrypt for fully automated certificate issue and renewal but I can't tell you when it's going live.
For now you can replace the current key/certificate like this:
require('json')
-- data from privkey.pem
key = [[
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
-- data from fullchain.pem
crt = [[
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
json.data = function()
  return {
    values = {
      mode = 'set',
      key = key,
      crt = crt,
stat, res = pcall(dofile, '/lib/flashsys/httpd_crt/save.lua')
if stat then
  res = json.pdecode(res)
  log(res)
  os.execute('/etc/init.d/nginx reload')
  log('error', res)
(11.12.2020, 07:39)admin Wrote: The script that you've provided won't work on LM. At this point it's not possible to fully automate this process without an external server. We have plans to add a service that uses LetsEncrypt for fully automated certificate issue and renewal but I can't tell you when it's going live.
require('json')
key = [[
crt = [[
  return {
    values = {
      mode = 'set',
      key = key,
      crt = crt,
if stat then
  log(res)
  log('error', res)
Hello Admin:
Is there anyway to fully automate the LetsEncrypt certificates?
best regards
Install the SSL certificate app from the LM app store.
(06.05.2022, 11:12)admin Wrote: Install the SSL certificate app from the LM app store.
Hello Admin:
I have tried, but SSL certificate app is only from local, and I want to access from outside.
When I try  SSL certificate app shows the next error:
Could you help me, please
best regards
Roger
There was an problem on our side not it should be working. But the certificate is only valid for local LM IP address.
If you need full remote access then you should use ZeroTier or OpenVPN (both are encrypted so HTTPS is not needed). Or you can use LM cloud for remote control.
(06.05.2022, 11:33)admin Wrote: There was an problem on our side not it should be working. But the certificate is only valid for local LM IP address.
Thank you, now it works...
best regards
I can generate the cert required, is it possible from a LUA Script to write to the Logic MAchine and overwrite the CERTS it already has?
